900 won't fire up!
Not sure about the charger but I don't see why not.
I didn't have anything around when I needed to test mine so I used a car battery. I just put a set of jumper cables on the car and some 12/2 electrical house wire on the other end and powered up the fuel pump. Worked great...If you go this route, be careful not to touch the ends of the jumper cable together!
Sounds like the pump may be your problem.
You should probably check to see if you have fuel pressure just to be sure you didn't miss the sound.
You should probably do a good visual inspection of the wiring supplying power to the gas tank.
*SOLVED*
I must have run it out of fuel or something from changing the tank....
I did what was mentioned and ran a line of household power cable from my car battery to the fuel pump. I instantly heard the system fire up and build pressure. Sled started on 3rd pull as usual. Haven't taken it out yet, was a bit early when i fired it up and my neighbors might not have liked it... MBRP can... go figure.
Glad to hear you got it running.
Thanks for letting us know. Too often people don't report back what the problem was which in the end means others don't benefit from it as much as they could.
