87 Octane
Anyone get stuck having to run this gas yet? Just wondering how things went. a bit worried with the long extended runs with this type grade of fuel. ANyone have any luck with any type of octane boost???
Ran it all last winter in my M1000. No issues. That's what the owners manual stated to use. Usually ride between 7 to 10,000 feet.
Never had any problem in any of our sleds that didn't have heads on them.
The stock M's (010 M8 aside) run better with the lower octane fuel. Up here we run 85. 10k+ feet
The difference between 85 & 91 is noticeable. (with 85 being better)
i don't mean to hijack the thread, but i've been running 91 in my M7 for a while (used to running it in my previous sleds), and was thinking about trying 87 this year, but i just put on a D&D single & can. so, i'm wondering if it would be better to keep running 91 with this setup, or would it be better to make the switch to 87? any advice would be greatly appreciated. thanks! :beer; :beer;
I've had to run 87. (Actually 88) as low as 5,000 feet before and didn't blow up on a 20-25 mile ride. The sled is an '05 M7 with an RKT 14:1 head. I just kept waiting for it to do something terrible...but after the ride I took the head off and no signs of deto at all...so I think 87 should be fine most anywhere for an older stock sled.
ran my 07 M8 for 5,000 miles on regular, have now added a full slp with bdx intake, am running premium now...
Sorry guys, I didnt explain myself..I was talking about the new 800 motor. I have a new HCR and am going to have to run 87 Octane for an extended period of time. I know the timing will retard if it gets down on the knock sensor and the Rpm;s will go down some to help save the motor and prevent a burndown. With EFI there must be a remapping that can be done to detune the sled????
Drop the compression!
HCRRIDER, If I remember, you are running a cross country race in deep snow terrain.
The 2010 motor is running 13.5:1 compression. Pretty high for 87 octane fuel.
If it does not effect your rules for racing, I would recommend calling Kelsey at RK-Tek and getting one of his heads set it up for a little lower compression ratio. With the added cooling and a slight drop in comp, you should be able to run the 87 all day long with no issues.
If a head change is not an option, you may be able to have the combustion chamber of the head cut, or go with a thicker base gasket for your cylinders.
The thicker base gasket will lower the compression, but will also change the port timing a little. On the 09's it ran better with port timing change, not sure about the 10's. Again, Kelsey may have some inside knowledge from testing.
D&D may also have some input if you prefer to deal on the East Coast.
Good Luck and Ride Safe!
