B
badass1000
I have a cylinder for 07-09 ski doo xp 800r. Just got plated by millinium technologies. Perfect like new shape and ready to go.
$425 with exchange of your damaged cylinder. cylinder must have plating damage only. $675 for cylinder out right with no exchange.
I also have spi dual ring pistons, and spi hyperdrive single ring pistons. Winderosa full top end gasket kit also.
Every thing you need to get your damaged sled up and runing again. I can even do the work for you if you can't.
Be up and riding again the next day instead of waiting weeks and months to get your damaged cylinders repaired.
I have seen some post their cylinders as for 07-12. 07-09 has 6mm y pipe bolts. 10-12 has 8 mm Y pipe bolts. they can be made to work on all years by just useing the smaller bolts or they could be drilled and taped to use the larger 8mm bolts.
