get the 4 wheel kit for the rear, will cure broken rods. In no way does it affect the "flex" of the single rail but the rods break from the leverage on the back of the rear inner wheels when your wheelies or chewing.1st cracked clutch 1200km
Engine failure 2300km lower MAG rod bearing
2300km also found cracked clutch again
Have also had a steering post break off
FTS suspension arm failed
4200km installing a new track before the season due to rods broken up the middle
I put one in at the start of last season. It helped that track last through the season. Hopefully on this new track it will improve the life of it.get the 4 wheel kit for the rear, will cure broken rods. In no way does it affect the "flex" of the single rail but the rods break from the leverage on the back of the rear inner wheels when your wheelies or chewing.
My first track got like 2800k km on it. Broken fiberglass rods and worn through rubber where the sliders run. It eventually tore through where the wheels run. Like the wheels and track tension Broke/fatigued the belting inside the track. I noticed the wheels bulging through track over time.I put one in at the start of last season. It helped that track last through the season. Hopefully on this new track it will improve the life of it.
Honestly it just seems that single ply 3.5" pitch tracks with 3" lugs are a maintenance item. Doo and Poo (2.75) are having similar longevity issues with theirs.The alpha track needs to be an 80 duro like the twin rail track. Too much wear, too quickly
The more performance out of the tracks we get the less durable they will be. They are almost like gummy tires for dirt bikes at this point. Maybe the option to have a very durable track but you lose some performance would be good for those of us that own a sled for more than two seasons.Honestly it just seems that single ply 3.5" pitch tracks with 3" lugs are a maintenance item. Doo and Poo (2.75) are having similar longevity issues with theirs.
