3" track
L
LiquidAuto
New member
I have a 2003 RMK 800 with the billet 900 union bay racing motor and twins. My sled already has a dropped and rolled chain case and U cooler ( so I assume the front cooler, if there ever was one in an 03 snocheck was removed), My question is, can I fit a 3 inch paddle on her, I am also acquiring a holz rear skid. I was hoping to run the new camoplast 3" on it. I unfortunately, am about 900 miles away from my sled otherwise I would have a look to see if there would be enough clearance. I also know I will have to change to a different driver to fit the newer pitch as well. So if anyone would happen to know what drivers as well that'd be sweet.
Thanks for the help!
nope, you need the avid case to fit a 3" did this mod myself btw
Robbie from avid in Montana, he makes them...its not to bad a conversion to do. FYI on my mod sled I went back to the camo 2.5, being totally honest the 3" did one thing really good, climb, everything else I did not like the way it worked, IMHO but figure the case, gears,chain,bearings,track,drivers ect ect you will have around 2500.00 done +labor. That's huge to put into a older sled. But if your highmarking it works very well
http://www.avid-products.com/
Yup it should go for you ( Ps id measure first cause some d&r will not clear, rare but we have seen a few) also sometimes you can squeeze a 16 " in there too
