Buddy tracking?Smart man right there
LOLAt least priorities are in order, spend the money on sleds, not the phone
When I look at the Catalyst it looks small compared to the Ascender. According to A/C specs its the same height a 1/2" narrower and 5 1/2" shorter this on a 154. As Boondocker 97 said earlier its the narrowed side panels / bodyworks that make it look smaller. I know when you stand / sit on it everything feels in the right place. I cant wait to get one on of these sleds and try it out. My thoughts are this is a light sled but is going to ride even lighter due to the lowered COG. I am looking forward to hearing your ride reports and thoughts on the new sled.unloaded my new M today, My dad a buddy and i all couldnt believe how easy it is to get on its edge even sitting on concret. Ive got a 18 mtn cat that ive loved and that has been flawless, but now it looks and feels big compared to the catalyst. the new sled feels good as far as rider postition. My buddy who has a axys stood on the cat and instantly said these feels awesome just where you stand and the handlebars and everything. Very excited to get a ride on it.
Krause can you measure the catalyst rear suspension mount hole distance? Sank uFiles to big won’t let me upload pics
To the ground or to the trackKrause can you measure the catalyst rear suspension mount hole distance? Sank u
From the front mounting hole/bolt to the rear mounting hole/ bolt. I’m wanting to know if it’s the same as an alpha. Thank you Krause09To the ground or to the track
How are the production side panels at the retainer clips? When I looked over the preproduction sled on display at the Jackson hillclimb, the side panels kind of hang up the retainers when removed. A very minor thing, but was the only thing I found as a negative. Just curious if they cleaned that up on the production sleds.you can see where the pull rope was rubbing on the wiring harness, I took the ground off and bent the eyelet so the cable is pushed farther to the center of the sled then i took a piece of heater hose cut it lengthwise and put it over the rope so it cant touch the wires. The hood and panels come off in literally a minute and there is good access to everything. the belt drive is simple and looks like it should work well the top pulley has a lip on both sides and the bottom pulley has a lip on the outside the belt has little room it can move side to side to compensate for any misalignment but doesnt look like it will be able to rub anywhere. it looks like the M6 has more clearance, but its only sits about half inch higher at the skid plate. it is narrower at the skid plate so less stuff dragging in the snow. the seating position is really nice easy sit to stand transition.
