I'm running a TKI lever so mine's already been off! But my question really is if were just a tolerance issue why didn't Poo just re-do the brake lever? I'd say the caliper was the real issue. When this issue very first popped up they said only some models were affected which made it sound like they got a bad batch of calipers from one vendor. Then all of a sudden it was software related and they did it to all of them. Which is cheaper? Replacing bad calipers or having one programmer update the software?Because some seem to have enough clearance and others do not. If my sled had no squeeze play in the lever I would first check to see if my pads were clamped on the disc and if not then just shave down the lever. Be careful though as the brake light switch is delicate and can break when re-installing the lever, if you are not.
