2019 Arctic cat Ctec 800 Alpha bog
Ever figure out your issue?
I adjusted the power valve cables and it didn’t bog but it’s just 1 ride last year. I’ll update in 6 months as I mostly spring riding. Haha
You ever figure this out? I have a 19 silber alpha with 2500 that has ran great until this season, it stutters after 7500rpm but has full power up to that point. Lots of guys say stator…
Interesting.
My stator troubles were always much more crippling.
I have a mtn fit hood, no headlight. I've had the bog since I put it on but the 13 pounds gone out weighs the bog. I know it's going to bog and it gets me sometimes.
I tried putting an air dam in front of the air box sensor to disturb the air but it didn't help.
Lost a stator last season probably cause of the no headlight. Havent had snow to see if the bogs gone with the new stator.
Is there a certain size resistor I can put in the headlights place to eat some excess power?
I have a ‘22 with 600 miles on it. Last year I had noticed a bog in the mid range. Didn’t think much of it towards the end of the season. November I put a Speedworks Stage 2 on it. Wasn’t able to check it out until a month ago. The bog was much more noticeable than last year. Appears to be normal until the machine is really warmed up. The bog happens from 3800 to 5600. Once above that, it runs great. I’ve had it at the shop for almost a month now. They’ve check every thing, reeds, compression, injectors, ECU and even put the stock mapping back in. They’ve talked to Arcticcat and Speedworks without any solutions.
On the stand, it runs great until the temp reaches about 110, that’s when it acts up. Next idea is to pull the crank and see if there’s any discoloration indicating a potential crank bearing issue.
Any ideas? Are we going in the wrong direction?
