Avalanche Advisory for January 23, 2020
View Full Advisory »
The avalanche danger for the west central Montana backcountry is MODERATE. Areas with a shallow snowpack and thin spots are of higher concern for triggering an avalanche.
Good morning, this is Jeff Carty with the West Central Montana Avalanche Center’s avalanche advisory for January 23, 2020. This danger rating does not apply to operating ski areas, expires at midnight tonight, and is the sole responsibility of the U.S. Forest Service.
In areas of shallower snowpack, roughly 5 feet or less, there is a possibility of triggering avalanches on the persistent weak layers at the base of the snowpack. A remotely triggered slide Sunday near Lost Trail ski area tells us these layers are still active in specific locations. This ran on depth hoar, near the ground with a four-foot slab, in trees.
Yesterday in the Rattlesnake and southern Missions, we found depth hoar in several locations, and it is safe to assume that it is present under most of the snowpack in the forecast area. This persistent weak layer showed increased strength in stability tests since last week, indicating it is slowly gaining strength. However, the structure remains very poor and capable of sustaining a propagation if a collapse is triggered. Thin areas where wind scouring has occurred, near buried trees and bushes, and rock outcroppings are the most likely places to trigger it.
In the past 24 hours, we received a few inches of snow throughout the forecast area. It was accompanied by moderate to strong winds, and wind slabs have developed on leeward aspects. Steep wind-loaded pockets were cracking and shifting when tested yesterday, and wind slabs released naturally in the last 24-48 hours in both the Rattlesnake and Southern Missions. Continued snow and wind will build more wind slab over the next couple of days. It is possible to trigger windslab in steep leeward terrain near ridge tops.
Conditions vary quite a bit throughout the forecast area, mostly based on snow depth. Some spots have been favored with snow, and others haven’t. Here’s a quick breakdown of what we’ve seen:
- The Southern Bitterroot, around Lost Trail, has the shallowest snowpack in the area and the worst structure. There have been three slides to ground here in the past 12 days, that we know of. Widespread surface hoar was reported this last weekend, so new snow and wind slabs may be sitting on this persistent weak layer. I would take the greatest care in this area
- The Central Bitterroot, Twin Lakes to around the Gash, has received quite a bit more snow, with depths to 6+ feet, and has better structure as a result. It is unlikely to trigger a slide in the deep areas. However, we are still seeing propagation propensity in thin spots, and with the base structure, there is a possibility these could propagate to deeper areas if triggered. No recent slides on the basal facets that we know of. Wind slab has been building, and at least one released in the last week on steep, unsupported terrain. Warm temps have done the low elevation snowpack some good, consolidating it and making it more supportive.
- Lolo has been getting its share of snow. Lower elevations where the snowpack is thinner showed a possibility of propagation this past weekend, while higher deeper areas showed lower propagation likelihood. Warm temps have likely put a crust on most surfaces due to the low elevation.
- The Rattlesnake has a shallow snowpack relative to other areas, ranging from 3-5 feet. There has been considerable consolidation in the snowpack in the past week and widespread wind effect. Except for isolated wind slab, I didn’t find any concerning layers in the upper snowpack yesterday. The depth hoar is present everywhere. It’s faceting further in thin areas and rounding a bit where it’s deep. It’s still not inspiring much confidence, avoid steep slopes and obvious avalanche paths.
- The southern Missions and Swan are stacked up deeper than the Rattlesnake and at higher elevations likely have some of the deeper snow in the area. Depth hoar can still be found, the structure is poor, but it proved difficult to trigger a propagation yesterday. That said, thin spots exist, and snowmachines can trench down to deep weak layers.
Due to warm temperatures, there is a melt-freeze crust to around 6500’ and 6800’ on steep southern aspects. Near-surface facets have developed underneath it, and it may become a problem with future loading. Currently, it is a minor inconvenience to ski.
Snow, wind and warming temps are in the forecast. Expect wind slab to build further and become touchier. The freezing level may rise to 7000 feet tonight, increasing the likelihood of thaw instabilities.
The bottom line:
It is possible to trigger large, deep avalanches, especially in shallow faceted areas. Wind slabs are a concern in steep 35º+ leeward terrain. Wet loose avalanches will become possible today.
In areas with deeper snow, it may be appropriate to cautiously step out into steeper terrain. Do your due diligence first. Check the depth of the snow throughout your tour and conduct stability tests. Avoid thin areas and convexities. Choose planar slopes without terrain traps. Follow safe travel protocols.
Always carry your safety equipment — beacon, probe, and shovel.
If you want to increase your competence in avalanche terrain, check out our education page.
Your avalanche, snowpack, and weather observations help us keep the public informed and assist us when generating the advisory. Please help us continue to better understand the snowpack, and submit your observations here.
Ski and ride safe
The post Avalanche Advisory for January 23, 2020 appeared first on Missoula Avalanche. |
