2017 M8000 TRACK ALIGNMENT
M
Oct 23, 2013
83
7
8
50
2017 m8000 153 sno pro ,the track
at the front of the rail is running closer to the hifax
than the other side ?at the back its more even
do i need to adjust ? thanks
Dec 7, 2007
1,010
160
Elkhorn NE
The drivers sets the alignment, If you measured from the front rail to center then matched that at the rear, You could shim the rear with a thin washer, I normally use a tape measure so each bolt is the same, On a 12 proclimb it is off by 1/16 to one side, Does not seem to be an issue.
sno*jet
2,829
1,299
my track rides closer on one side of the drivers. not centered. has from day one. I let it go and just follow the manual's alignment process (make sure rear axle is centered) and have never had any issues. Was thinking if i ever have my drivers off i might move them over a hair but IDK.
N
Jul 23, 2008
66
38
18
Is it possible to adjust the driver position along the driveshaft? Alignment at my front idler wheels is off by a good .5"
