2016 axys thumb warmer not working
scottbilt95
128
golden, colorado
scottbiltracing.us
thumb warmer not working at all. hand warmers work when normal riding but that great at idle like my 2014's did. searched SW threads and found a voltage reg could cause hand and thumb warmers not to work. any way to bench test thumb warmer (ohms?)
much thanks
A
Mar 14, 2011
510
124
Saskatoon, SK
My thumb warmer kind of feels like it isn't working. The grip warmers get hot enough, but I always wish the thumb was warmer. I stopped one time and felt it with my bare hand and it felt like I was getting some heat off it, so I don't think it is totally faulty, just underpowered / underinsulated.
Sheetmetalfab
7,911
6,673
I think they all suck but are working. Put another piece of foam tape over the backside of your flipper so the wind does not cool it from that side.
Plus then you won't be able to pin it all the way.
Should keep the thumb warmer.......
I've removed the plastic film on the back of mine to achieve wot.
Rode in -20f last week with no issues.
Check the connections.
CO 2.0
2,994
Fort Collins, CO
much thanks
They dont work at idle. They work once rpm is brought up with throttle.
scottbilt95
128
golden, colorado
scottbiltracing.us
and the verdict is...
after getting near frostbite on my thumb last week, i used cork insulators on the bars and on the back side of the throttle flipper. fyi even at WOT the cork didn't hit the grip. i haven't rode yet but the grips get seriously hot at a sustained 2500 rpm. the thumb warmer does get hot but not like the grips; but better for sure. i'm not sure how i will like the increased size of the grips but i don't think it will be an issue.
thanks for all the tips and chatter!
jeff
Sage Crusher
3,268
1,196
Rock Springs,Wyoming
Sometime like in the "old days" we back sprayed the bars with great stuff foam- still works on the Axys Pro taper bars- but the thumb heater is very very non existent compared to the hand now.
Replaced it under warranty but still the lame "old" not enough heat
can anyone tell me how the thumb warmer works? Having started without accelerating, I could find 14 volts with the strong heating turned on. But I couldn't find voltage at low heat level. Perhaps I mixed something up or I had to give it more throttle as I understand it, out of three wires there are 2 “+” and one GND?
Axys 2018 pro rmk 850.
