C
I talked with Jared and discussed the EBC function and it looks like with the 4 psi actuator it throws off the ebc. I am running about 2 psi less than what the boost is set at on the box so I just compensate by 2 psi for what I want to run for boost.
Can you explain what you meen by this? "throws off the ebc"
I am running adjustabel actuator and ebc on a 2012 HCR
I had my ebc set at 11psi last ride. But I only saw 9psi on the BD boks (max psi) and on the ebc while running.
i first was thinking that it was the exhaust spring that gave in for the pressure. But I got a tip from a norwegian community that i should try to set the adjustabel actuator to 8psi (I would get 5psi with the ebc on 1psi before) and see if that helps. haven't got the changs to test it yet. And i don't see why it would help, but doesn't hurt to try it
