You know it works better the other way... Right? lolSorry did not have any pictures of it in the shop!
Here is mine so far.
Have a few cosmetics and a couple of functional items left to do.
Things I've done to it:
Exhaust valve drain relocate
belly pan block-off
narrow ski stance
airbox sleeves removed
tighten throttle cable
move kill switch
low windshield--white
Skinz front and rear bumpers
nose pan vents
XXXModRods 5 vent kit
Goggle bag under hood
Riser bag on handlebars
Seat bag
Install Gas rack--Mtn Addiction
driveshaft rivet
sway bar arm rivet
Tunnel wrap
Dynaport Barker can....and put back on Ethanol setting
Have 570 miles on it now.
MuffPot installed.
Tighten belt deflection
adjusted belt deflection.
White side stripe LE panel stickers removed and went with grey side stripes.
Install Teth-air
Wildchild gauge lifter
different snowflap--ManBearPig
SLP dash vent
Things to do still:
Turn up oiler. 2 turns?
Tighten track--need to do this again.
black powdercoating spindles, rails, running boards, seat post
handguards
Move steering rod linkage for tighter steering (handlbars hit me in the nuts when I turn them all the way)
Team TIED is still sitting on shop bench...might try that out too.
Add more miles!!
