Since you asked yes, for what they charge you are getting reamed. Of course C3 utilizes the stock case center to center so they had to utilize a tensioner. CMX just didn't put enough forethought into their design or it would be closer to the two sprocket no tensioner design.
With the Polaris design you have twenty ratios available from 1:1 to 3:1 with the same belt. You will never need anything but a 70T belt if you use it as intended. If you want to split those twenty ratios further then by all means make a tensioner.
--Why is the brake rotor still located on the jackshaft instead of the trackshaft?
--You would get fewer RPM of rotating mass, lower cg, and brakes would still work if belt/chain were to fail if brake was on trackshaft.
as far as i know CMX doesn't have a tensioner anymore, atleast on the pro kit..... just thought i would let you know that...
Does anyone think there should be a tension adjuster of some sorts??
Or do you have to buy spare gates belts and change every other weekend??
If so im buying some stock in Gates??
How many of us have cars with a belt nearly identical to this one running the cams,and in some cases in a 0 clearance motor. These belts last 8-10 years and 80,000 plus miles without issue, why would this be any different?
I think were forgetting that they use these type of belts in top fuel drag cars that run at 7000 hp, it takes over a 1000 hp to just run the blowers on them :shocked. They do occasionaly fail but this is under the most extreme conditions. I dont think they will ever fail in a 150 hp sled![]()
