Soooooooo reading between the lines....are you saying possibly more power with compression ratio change and different port timing?
Merlin, While I agree that Factory Polaris would not want those that are tied to the company for whatever reason to put out in the public forums the changes that they made... I would not consider it an admission of design flaws...
Ok sorry for the long delay it took some time to connect with Hanson Racing. I was told for a fact that all of the cranks are now from Fuji which I think we already knew and that indeed the cylinders have also had a physical change besides just the part numbers.
The port timing has also changed and Eric suspects that the compression ratio has changed slightly. Eric has not had one of the new 2013 800 motors torn down yet to but he has direct knowledge with the new fuji cranks which he states was a major improvement.
Correct me if I'm wrong, but I believe the 2012's came with the Fuji crank as well?
Yes, some of the 12's came with a Fuji crank. I do believe it was the assaults that came with them and the rmks came with the polaris crank...
They were phasing out their supply of polaris cranks.
I looked into it more and what I can find is the 2012 800's were built with both the Polaris (Type 1) and Fuji (Type 2) crank, regardless of Assaults or Pro RMK's (from the parts fiche). I'm pretty sure the Assaults were built after the Pro RMK's, so it would be make sense that at least some Assaults have the Fuji crank. All 2013's were built with the Fuji crank.
2012 Pro RMK: http://www.polarispartshouse.com/home.aspx#/Polaris/S12CG8%2f%2fCH8_800_PRO_RMK_155%2f%2f163_ALL_OPTIONS_(2012)/ENGINE%2c_PISTON_and_CRANKSHAFT_-_S12CG8%2f%2fCH8_ALL_OPTIONS/86857/86894
2012 Assault: http://www.polarispartshouse.com/home.aspx#/Polaris/S12CN8%2f%2fCY8_800_RMK_ASSAULT_155_ALL_OPTIONS_(2012)/ENGINE%2c_PISTON_and_CRANKSHAFT_-_S12CN8%2f%2fCY8_ALL_OPTIONS/86088/87040
2013's (No Pro RMK's listed yet, switchback 800 listed): http://www.polarispartshouse.com/ho...RANKSHAFT_-_S13BA8//BC8//BD8//BS8/91664/91811
Joshua, I was told all of the long track sleds now will have the Fuji crank. It looks like that makes sense with your parts research.
yup I agree all 2013's have Fuji cranks, while 2012's have both
Iwill also have a 2013 cylinder in my hands tomorrow.. So, I should be able to tell what changes, if any, were made
