Summer of '86
Ahhhh......good times
Yes, new up-pipe gasket after the first incident. Torqued the heck out of all hardware. Took sled to Vale, and it happend again. Bolts were all loose. I have found that all exhaust hardware (stricly when using the new MBRP provided bolts in the up-pipe and straight pipe) has to be initially torqued, and then run the engine good and hot, then torque a second time while everything is red hot. No diffeent than the ole '86 camaro header bolts...
I uesd the blank fitting on the factory plastic elbow to attach the crank case breather to. I used a ruber hose with a sharp 90 bend and then straight back to the roll over valve. I am almost sure that the freezing is taking place right in the plastic elbow fitting or at the sharp 90 degree bend right beside the factory elbow. With -20 plus degree air flowing through that plastic elbow for an hour straight I can see how some freezing could occur. The 90 degree rubber hose does sit right against the hood as far away from a heat source as possible.
So two thoughts. One is a hand warmer on the crank case vent line right next to the cold air intake. the other is a perssure release valve in line after the roll over valve that would "blow off" if the pressure in the crank case starts to build up due to a frozen or blocked vent line. Any thoughts?
He did, but he had to as there was a piece missing of the gasket from a bolt being completely gone and the exhaust blew it out.
Why you couldn't put a automotive type crank case breather on instead of putting it in the cold air intake manifold? Well that's what i am going to try. I used them on my race bike motors all the time, just not at subzero temperatures.
