2012 BD turbo pro first ride report?? Issues?
The #'s you posted that you got from Jared, are the ones I was telling you about when we spoke on the phone. I tried them out and did not like the map at all. I even tweaked it a bit, but went back to the #'s that I gave you from my sled the other day. Not saying those #'s won't work for you, but from my experience, the map I gave you one the phone, are much crisper as far as bottom end response for me.
Good to know. Ive got your in the map on my #3 setting so ill be running your #s. Excited about having good #s
Thanks again.
Rode with Struthers this weekend and he uploaded a new map in my box and made some adjustments. Ran 10lbs all weekend and the sled didnt miss a beat. It ran great. Awesome on the bottom and pulled hard all the way through. I truly could not be happier. It runs so clean and good that I honestly dont even want to mess with it....although I probably will :) I am running 72gram EPI's and pulling 8200-8300rpm with a 54/46 helix.
Anyway we could get you to post those numbers AO? Thanks.
Id like to see your numbers too. Im headed to Cooke next week for my maiden voyage.
Did you get a chance to look at charge temps.
Not sure about the timing key....I think so(Carls Cycle set it up). And I dont know the changes that were made in Super Tuner mode, but here is what I have...and I was running about 3.5-4 gallons of 110.
4300 06 08 00
5100 07 11 13
5900 20 25 31
6700 25 34 32
7500 25 34 35
8200 25 34 34
8500 25 34 37
Acel 00 00 08
Hope this helps guys.
The numbers mine came with weren't even close. My dealer set it up with his own numbers, ran great except for 2/3 @ 6700 rpm and full throttle 7000-8000. I leaned it out so hopefully that fixed it. I'd be happy to send you the numbers but I ride 3-6k. I hope you figure it out bud, the thing freaking rips!
where is conway and what are your numbers having a det problem
