Well first off the loose plug will cause det7. Second unless your trying to save money on race or av fuel then take the timing key off it does u no favors on bottom end.
The updated fuel numbers on their website for high altitude should get u very close. The clutch springs they recommend work. I would suggest using 10-72 Polaris weights at that elevation. The stock helix would probably work just fine but the turbo helix 42/48 is better.
If your using EBC smart then you will have a harder time tuning but will b happy when and if u get it dialed. You will also have to lean it out more then before with the four injectors but mainly because you have so much more ability to tune in every rpm in conjunction with boost. If you understand the boondocker box then you can tune your sled like no other company can.
Get yourself an A/F gauge! How can you own a turbo without a tool to tune.
An A/F for turbo application is the only way to go.
All that being said I have the new torque air box with cold air intake and new EBC smart and just got done riding at 8500ft and everyone that saw my sled or rode with me said it's far more responsive than stock(zero lag) with a lot more horsepower
Look over your installation to make sure everything is right and go with recommended fuel settings and clutching from boondocker, add 50Av/50premium turn boost to 10 plus and I'm sure you will get it figured out and have a great year!
So you know that his plug started the ride tight?
So your disputing that a loose plug which he stated wouldn't cause det7?
99% of the time a loose plug is telling you something. If you don't listen and assume that the plug was loose all along the next time there will be a dime size hole in your piston.
There is a slim chance they forgot to tighten it.
Sledwolf knows there is a problem bigger than a tech left the plug loose. We will help him get his BD kit running. Silber should get paid by BD for providing tech support after hours![]()
There is no doubt that you Boston racing, Silber, and other Silber dealers have taken your customer service a notch higher than BD. You are definitely being rewarded by taking customers from BD which you 100% deserve. I'm not doubting your knowledge or experience. BD runs their business 9 to 5 and sometimes that's not enough.
But bad rep'n me for stating the obvious and saying mine runs great to give sled wolf the confidence that the kit works when bugs are figured out and giving him the start of how to fix it?
Sledwolf what clutching is in your sled? What are your current fuel settings in your boondocker box? Does your boondocker box read 0 when it's at idle(check in stats screen)? Do you have EBC smart? Are you in ALT compensation mode?
I would tune it without the electronic timing key, then add the key if you feel a need for it later. I agree that a loose plug is almost always a result of det, not a cause. But if you're not sure you the plug was tight to begin with it's a moot point.
Remove the timing key, double check that the plugs are tight, and run it again. Report back.
Curious if you got it worked out?
@Sledwolf. I was also having issues but I coudnt reach Jared. I talked with Reid Hedlund at Boondocker Canada and got some answers. I ended up with the following:
Lo Mid Hi
4300 10 13 09
5100 09 11 13
5900 20 25 31
6700 25 39 37
7500 25 42 43
8200 25 39 39 I will +2 to the mid and high next ride
8500 25 38 41 I will +2 to the mid and high next ride
* I also went from 50/50 112/92 down to 70/30
* I had tried close to these settings before without to much of a change. I think the biggest difference maker is the CAI. Without a doubt. Hopefully this helps.
Btw: Thanks dcturbo and dmkhnr for your thoughts on the CAI.
