what kind of clutch do you have on yours and what elevation do u ride at?
All Yamaha. Had a shock wave and thought it was junk. I ride from 8-10
I have had it since nov 07 turboed since january of 08 pushing 3000 miles with turbo no problems except exhaust, bellows and header had cracked. Also I run a manual boost control. Only thing left on it that is stock is the plastic and handle bars.
so do you have any stock engine or do you guys have low comp pistons?
alright thanks for all the help and just wondering how does the mcx 270 kit compare to a push turbo kit like speed, acc., how much power does that kit make?
Drain your overflow bottle down to the normal level and make sure you are full of anti freeze in the rad. You might have to lift up the front of the machine to get all the air out. Also open the bleed on the back of the tunnel heat exchanger to let air out. After you are sure all the air is out and you are full go for a ride and see how much you loose and see if it fills up your overflow bottle. If it does it could be the rad cap but I bet it is your head gasket leaking under boost.
but don't you think if it was the head gasket don't you think it would be blowing antifreeze all over the inside of the sled instead of just on the right side or no??
depends on how big a leak you have, if its small it will just pressurize your cooling system & push coolant out your overflow first.
Gaskets are about $30 here in Canada, I would replace the aluminum head shim with a stainless steel shim. Or better yet goto Powderlites o-ringed shim, not sure if this works better but I would like to know. This year I'm going with a 0.060 stainless shim and two gaskets instead of spliting one. As for labour, the engine would have to come out so to do the job someone who has done it before it could be done in a day but it would be tough.
It would be a good idea to goto ARP head studs if it doesn't have them already. Also while you hhave your head off check to see if it is flat, and do valve clearance.
Good Luck
