Advantages are suppose to be less rolling resistance in a bigger wheel and less resistance to holding the edges of track flat when carving to help lay over. Is it true? You decide. Mountain machines makes a nice set up, or you can make your own with some polaris parts from newer year and a shorter axel. I believe you can do this for under 30 bux.
What effect does the hyfax take with the 2 wheel kit? i would assume they wear out faster.
Nope...the hyfax wont wear from installing a 2 wheel kit..it will wear if you dont maintain proper track tension, dont use scratchers, dont keep the hyfax lubed..
but other then that, its just fine..
Somebody will help me out here or you can search since I dont remember the part #'s. But you will need the two outer plastic spacers and a shorter axel. I believe you can doo this all for under 40 bux. If no one replies just goto Babbits online and look at a 07 dragon rear axel parts. You will find the part #'s you need.
