the track is plenty loose,i guess on the next ride after it blows anouther belt ill flip it and check the track,it spins good on the stand, i have felt the clutches everytime i blow a belt and thier not even hot,i got the side vents plus when all of this happened it was -20 degrees both times so they would be getting lots cool air..it reves right around 8100 off the line till it starts to really open up then its at about 7900,it really goes though when she isnt throwing a belt off,i guess anouther thing also is that the last belt i was using was a ultimax 3 and it didnt shred its like someone pulled it apart in one spot
Just a thought here, did they change the gearing in your sled when you got the diamond drive replaced? It sounds like an over rev condition to me.
On my M1000, if I am doing high speed stuff down a lake and then hit an icy spot and then over rev'ed, I would kiss that belt goodbye. there would be no load on the track at high rev's to keep the belt in the primary.
My freind and I both blew belts on the same lake within 100 ft of each other. We compared notes and realized that if we over-rev the motor in those kind of conditions , the belt would climb over the primary and then destroy itself on the primary clutch towers. Jumping could give you a similar condition. Also, stick with cat belts, we found the other makes just didn't hang in there. At least that's what we found. Belt heat is definitley a killer too.
Somebody with a good plastic welder couldn't fix your side panel hole? Or was it too ugly?
Hope this gives you some ideas, other than the obvious. Good Luck,as they are awsome machines.
