A
I currently have a 2019 summit 850 with the 2.5" lug. Was thinking about switching to a 3" lug next season. Any pros and cons to help with decision-making?
first part is true, second part is not true on 165 as there is enough floatation that 3 inch is better, in the 154 is where you see the biggest difference in the 2.5 to 3 inch as the 2.5 is lighter so better track speed which helps it stay up instead of treching more with the 3 inch and if you have good skills and good throttle control the 3 inch is awesome in the 154 too, just different approaches. cheers daveI can not offer any actual advice but a couple things that I considered before ordering my '22 summit 165 2.5". I friend ran a 3" 165 on his '18 summit and threw several lugs and had to change it out. The reason is that he does not only ride the mountains, he also rides fields where he rips across the field at WOT and the track speed was too much for the 3". Since I also ride fields as well as the mountains and I don't want to be dealing with track failures, I leaned towards the 2.5". The other thing that I found interesting was that I watched a Chris Burandt video where he discussed HIS preference and IIRC, he said that HE prefers the 2.5" over the 3". IIRC, he said that the 3" trenches too much and that the 2.5 gets on top of the snow better. So, for me, It seemed that the 2.5 was better than the 3" for both riding the fields AND rising the mountains which is what I do. What will work best for you would depend on the type of riding you do I would think.
You could be right. I was just sharing what Burandt says on the subject and IIRC, he DOES ride 155". I believe that Chris Burandt would qualify as one with "good skills and good throttle control".first part is true, second part is not true on 165 as there is enough floatation that 3 inch is better, in the 154 is where you see the biggest difference in the 2.5 to 3 inch as the 2.5 is lighter so better track speed which helps it stay up instead of treching more with the 3 inch and if you have good skills and good throttle control the 3 inch is awesome in the 154 too, just different approaches. cheers dave
Ohhh I’m pretty sure he’s right…You could be right. I was just sharing what Burandt says on the subject and IIRC, he DOES ride 155". I believe that Chris Burandt would qualify as one with "good skills and good throttle control".
Chris is not that good yetYou could be right. I was just sharing what Burandt says on the subject and IIRC, he DOES ride 155". I believe that Chris Burandt would qualify as one with "good skills and good throttle control".
