Not trying to hijack the thread I just didn't want to start a new one with the same questions.
Diamond Dave. I thought I saw on Indy Dan's web site that he said Polaris piston's are the best out there. My kid is thinking buying OEM pistons, rings, and gaskets. Would that be better or worse than the MNTK. I am not arguing or being a smart asss. I haven't messed with two stroke engines and know very little. In the end the decision is up to my kid. Thanks in advance for the info Dave, and you too! PPK for the thread.
I apologize for not seeing your questions here until today. I will answer the best I can.
First off, I have the utmost respect for IndyDan and have recommended many customers with Polaris motors to him. I've installed two of his reinforced mono's with MTNTK fix kits. Both have been performing excellent.
His recommendation for the stock piston is IMO more based on his modified cylinder and tightening up of the cylinder wall clearance to the piston. Dan prefers a cast piston. Dan reinforces the cylinder skirts and tightens up the nicasil plating so that the stock piston fits much tighter. This scenario makes the stock 800 CFI much, much more reliable especially if we're talking about a 2013 and newer monoblock.
I am (and have been) a huge proponent of the MTNTK Fix kit. They were the first shop that was able to actually fix the Dragon motor around 2010-2011. A motor that another shop that has been mentioned said couldn't be fixed.
I have installed approximately 25 MTNTK Fix kits since the inception of the Fix Kit. I do always use OEM seals, gaskets, and caged bearings with the kit. I have had 2 of my personal sleds ('09 CFI-4 and '12 CFI-2) crack cylinder skirts with less than 400 miles on each sled. Luckily both were found during off-season teardowns. Proper warm-up's, extra oil didn't matter. On the '09, I used the even thinner cylinder skirt monoblock. That engine is still going with over 4,500 miles today.
The nice thing about the Weisco piston in the MTNTK Fix Kit is it fits a properly honed, used cylinder much better than a stock piston does. And the 3 motors that I have torn down after approximately 2,000 miles each have shown 0.001" - 0.0015" collapse which equaled to a max of 0.007" piston to cylinder clearance. I have measured stock pistons that had in excess of 0.012" - 0.016" with alot fewer miles and have never seen one with less than 0.010".
Someone else asked about using the kit with a PAR head. This kit works great (in fact runs even better) with the PAR head. I would just recommend (and emphasis) that you verify proper squish (which should be done anyway) when you install new pistons in any motor.
As for a fuel controller...the '11-'12's were fat enough with fueling that you can get away with fix kit's, heads, pipes, reeds, etc without the need for a fuel controller. However, 2013's and newer run a much more leaner mid-range than earlier CFI-2's. You can install a Fix Kit in 2013-2015 without a fuel controller BUT if you install a head, pipe, and or reeds, be prepared to possibly needing a fuel controller.
