13 800 with light crank??
TRS,
You seem to be in the "know"... Are you suggesting the new crank is a Mape again after the 11 and 12 problems?
Just speculation. I have always been a Fuji fan. I would like to see the addition of a thrust clip/ring on the PTO bearing though.
With Fuji building the "pork chop" crank, I believe they will get crank balance correct. This is truly one of my concerns. The other is with the primary's thrust affect on a 2.5# lighter crank. I truly don't want to go through the BRP "out of phase" issue that has (quietly) plagued them. Suzuki uses a bolt on weight for balance.
when I built my engine with the lite crank, the bearings looked the same to me as a regular crank and the oilers on my case are in the same spot...I sure hope that they are not grease lubed...
crank
The lightweight crank I am using is 2205190 now just trying to figure out what top end to do
also have a new stock 800 crank if anyone is looking
