C
catf1000s/p
there is a new fork heading to dealers to fix these problems
The reason my reverse would not work is that the jackshaft had constant torque on it from the engine. meaning the belt was runnig to high in the sec. and as soon as it popped out of forward it would spin and not let the reverse engauge. I shimmed the sec. farther apart allowing the belt to ride lower in the sec. No more spinning clutch when it pops out of forward, so now it has a chance to get into reverse. Tried it 6 times in the shop. Worked everytime. Now we will see if it works in the snow.
You have to run the belt deflection looser than most guys are used to.
With the belt tight, the secondary and jackshaft spin between the time it is out of reverse, but not in forward yet, this rounds over the teeth on the forward gear, preventing it from engaging.
Everyone will be getting a letter on this, telling you if you have had any grinding, not to use reverse until the upgraded parts have been installed, no eta on parts arrival though.
My M1100 Turbo has had absolutely no reverse problems. It works perfectly.
Build date Dec 20.
Tim
