I just took my sled to the local dealer for a once over prior to the season. I fought with the bog most of last year and thought fuel, but no matter what I set my Boondocker to, it would still bog.
When the mechanic went over my sled he found one of the MTX weights had come loose and shifted over in the primary. I haven't tried the sled yet this year (will on Saturday) but I'm guessing and hoping that is the problem solved.
finally got a minute to hang my bd box and high volume nose cone... noticed big high number differences on another post... our sleds are set up similar...not looking for the easy way out but wondered if I could get your numbers.every sled's different, a little...my 09 has a speedwerx y-pipe, stock pipe and aftermarket can, with big air intake, modified air box for more air....at 5000 rpms my settings are -2 -3 -2, and 6500 -1 -2 0....i have no bog at all, either before or after valve opening....no burndowns, and i use the 6000-6500 rpm area alot....i arrived at my fuel settings by deliberately adding too much fuel until it bogged and gagged, then leaned it out until it ran, watching egts all the time...after it ran clean, i checked plug readings and correlated that with egts....i tried the sw pipe and stock pipe back and forth several times and concluded the stock pipe just plain ran better....on the dyno, i only lost 1.2 hp on the top end, which i gladly sacrificed for the overall better running of the stock pipe...as i stated in another thread, not bashing sw, but these are the results of my setup....![]()
Since my 1st post I have f _ _ _ed with the bd box a ton including having a couple bd reps messing with it still up and down like a bad girls underwear.The last 2 weeks i have broken/cracked the top all around where the pipe goes into the speedwerx can "apparently a recall", ordered a new MBRP can took my pipe off to install new can noticed a crack about 4" thinking mabey i leaned it out and it got real hot, but there was no indication of this on my egt's so i welded the crack put it all back together, went out last weekend in about 4-0' of fresh pow machine was falling on its face when it would get warm around 5000 to 6500 rpm, so i richened it up ran worse. Seemed like when i would shut it of and let it cool off start it smash it in deep pow do a big climb witout letting off it was fine soon as i would turn to come back down same old thing bog did it all day really pissed me off. So i decided to do a bunch more research before i dispose of it, and have seen alot of talk of the power commander.I talked to a fellow named Dustin @ SLP told him my frustration and this is what he said would most likely clean up my problem as he has corrected it on a number of 09 1000 already let me now your thoughts.Those of you that have 09 M1000 count yourselfs lucky because it is one pain in the ***.
Pipe Kit 09-876
Power Commander 70-128
Clutch Weights 40-118
Clutch Spring 40-70
Helix 52-44/36
Rock Rollers 40-109
Air Intake 14-305
