Do you know when the Turbo kit was installed? I am just wondering if this was a kit that never got updated to the ADA kit. I think the first kit didn't come with temp sensors, not for sure on that though. Do you have temp sensor in your airbox? What is your charge temps showing on your stats screen. Maybe you have a bad boondockers temp sensor which is messing with your tuning once it gets hot or warms up.
Do you have a push to pass button you can setup to capture stat when its bogging? Really seems like tuning to me. Justin at code red told me low psi is for the first 1/3 of boost you have set. Mid psi is 1/3 to 2/3 of boost. And Hi psi is for 2/3 to WOT. (IE. 9 lbs set, low psi is 0 -3 lbs, mid psi 3 to 6 lbs, high 6-9 lbs.) Then you can tune specific rpms by adding fuel to 3000 5000 ect. If it seems to be burble bog/rich at 4000 lo to mid throttle try adding fuel to low and mid 3000 and low mid 5000 to verify this. Try like 5 points in each. Ride it and if its noticeably worse then you are rich at those spots and take fuel away. Try and make it worse first to verify you are going the right way at the right spot. If it gets worse then I would try maybe 3000 -5 -5 0 5000 -5 -5 0.
Not sure if you already know all this and have already tried all this if so disregard.
