did it look like a could seize
i know it went lean i think at the low 5000 # obviously since it blew but its been irratically fat seeming at the same #... it blew up at 15 mph going down the road slow on and off the gas. talking about the lo # starting at 7200 and higher, why would you ever want to be at anything except 0? when are you ever at that rpm and not pretty much wide open? i thought if you had any positive # there it would go fat when on and off the gas? i know i took off from a lower elevation than i ever do and it was colder than usua, i just never blew up and engine because of a lean needle ya know... and i thought i was a master engine blower uppppper!!!
Way to lean. I ride 07 m1000 with reflash and slp y-pipe and pipe and can. I pull 1150 on the egts at wfo on a long pull plugs look good. For some reason or another I have a mid range lean and if I try to richen in up around 5000 rpm it bogs. So i just watch the temps and blip the throttle when I am on the trail. Now if I code only get my clutching solved still blows belts.
Any chance you would post your numbers? I have the same set up as you, except no belt problems. I put in a RKT clutch kit and side vents for cooling and have no belt issues. I do however have a bog/hesitation around 4800- 5000......can not seem to get rid of it............its exceptionally bad when the outdoor temp reaches 35' or more.......
Egts top out 1200......
thanks
Mine bogs the worst when at WO, let off then back on it............it takes a bit to catch up.....boggy....gurgily.....
I have the 36 helix..........made a vast improvement..but did not eliminate it....
Also out of curiosity......I see some are running 64/56 gear ratio.....my 07 comes stock with 60/34...........that seems like a huge difference...can anyone explain how much of an effect this has on performance........
07 M1000 162"....Slp pipe, can, and Ypipe....what are you riding
booondocker fuel box and digitron egts, RKT clutch kit.........I'm afraid i dont know any thing more about the helix other then its a 36.
The only reason I dont know if the bog is clutching or gearing is because it bogs worse above 35'..........and better when its cold..........25' or below.....( I know they run leaner the colder the air.....just wouldnt think the bog would be so different)
However I also didnt know the gearing could be changed so much in these either..............
stock gears for a m1000 are 60/60 you said you have 60/34??????
A lot of people like the 56/64 gears or 57/63(m8) gears I'm am going to get mine clutched right for stock gears and go find the best running geared down one I can and see what happens, but I think either of these gears would benefit me due to my weight and how hard this sled hooks up.
It builds more hp when cold, so when its cold you have the power to pull the belt and engage the secondary, but a little warmer you don't, but you may be able to lean it out a little when warm and bring it back. Or loosen up the helix some more. there are two ways to engage the secondary, one you over power it forcing the engagement, two it falls right in with the primary engagement. so you may be able to pull a steeper helix and make it work or you need less spring tension on the bottom. When I was in cooke running a 060 built it would fall on its face and then take off(could get the sec. to engage fast enough) the 46 belt work though due to slippage on the bottom, but when I dropped down to 7000ft on the road with the extra power I could run the 60 and it pulled harder than the 46. Went to a slp 44/36 helix with stock spring and it worked better with either belt. if you have the mtx weights or adjustables, you could try taking weight out of the inner hole to slow down the engagement and reduce the bog. But thats not to say its not fueling either just some ideas. and I'm still not perfect with the clutching stuff.
