I have an 07 600 rmk that is stock, sled is ridden at 8-10k, all clutching is stock. When getting into a climb the motor once loaded down sits in at around 7700 rpm. The springs are good and I am running 54 gram weights so I know the sled is not backshifting correctly, i see that some are running epi's belly buster weights with a steeper helix in the d8's and having success. What helix are some of you running in your 600's to achieve the same result?
