Will you accept a semi-biased opinion?
The 07 D7 RMK is one of the best sleds Polaris ever put out! Extremely dependable and lots of power for a 700, many dyno tests were reporting 140-143hp back in the 06/07 season. Will go almost everywhere and easy to toss around, but lacks some of the torque of an 800 for big climbs. The only required Polaris updates that come to mind was a re-flash in 07 and a chain case cover mod that included heat tape and a metal bracket that prevented the plastic from warping. If you pick it up, make sure you check the seal around the headlight assembly and windshield tabs to prevent snow injestion into the airbox. I would also recommend you replace the factory foam intake filters and add a few more filters to improve air intake. Also seal up the airbox drip hole located directly over the mag side exhaust valve spring (you will see rusty water splatter from the valve hole) and drill a new hole off to the side. Most people have also replaced the factory W/E air shocks, the 07's were mushy. Once again, it's not as big as an 800 but keeps up with them in most conditions and will get you back to enjoy another trouble free day.
