T TCar Member Jan 13, 2008 #1 Does anyone have any suggestions, my 07 800 159 will make 2 beeps when you let off on the throttle form a med/fast speed. There are no lights coming on and the power is good. RER works fine like normal. ???? beats me what is going on. TCars wife. the beeping beitch
snowbank New member Lifetime Membership Jan 14, 2008 #2 check electrical connections near the carbs we had one do the same thing
M MtnCrazy New member Jan 14, 2008 #3 Mines does that sometimes when my tether cable is not pushed on tight??? All I can think of...
Shermanator Well-known member Lifetime Membership Jan 15, 2008 #5 Tether cable, mine does the beep beep at idle when the cable isn't right on! Sherm
G Go 4 Ride Free Member Jan 16, 2008 #6 It's an electrical connection on the RAVE system. Mine did it untill I noticed I had forgot to plug a connection back up.
T TCar Member Jan 23, 2008 #7 Beep Beep Yep you were right on !!! it was a connection on the RAVE valve. sled should rock now..... Thanks Beep Beep
