D
dman142
So to recap:
1. Replaced the entire fuel delivery system so far.
Pump assembly and injectors.
2. Will only start with a cap of gas poured into the cylinder.
3. It will run fine after that.
4. Indicates good charging on the mfd.
the ecu is still flashed to a htg 975. Problem here? Can't see how that's going to fix the issue. Spark is great. Fully rebuilt motor.
The injectors are not firing on their own when the recoil is pulled. Once gas hits the cylinders, it's fine.
Ecu issue or stator? Flywheel looked fine and no glue issues or separation.
There's not much left to replace.
Thanks.
Thanks.
