3
307in406
New member
I ride an '06 carberated M7. When going through deep powder my sled starts acting funny and starts cutting out. When I give it more throttle it doesn't increase in RPM's or speed obviously. It doesn't decrease it just won't increase, like its hitting a wall. If I stop and sit for a couple of minutes or if I feather it, maxing the throttle out, across a meadow it seems to "break" free and run like it should. If I unload off the trailer and ride the trail to where I need to go it hauls and everything is fine, its just when i start going through the powder. I have looked at the boot between the carbs and air box and everything looks tight and good, so I don't think that its sucking snow in anywhere. I do usually mix sea-foam in with my fuel to prevent freezing up. It is running rich also, running down the trail, through the powder, and just sitting there idling it runs rich. I have taken it to a mechanic with the same sled I have and he is running the same jets as well as the same needle and seat positions.
Has anyone ever encountered this problem or have any ideas?
