06 M7 153 Clutch set up recommendations
None right now, still completely stock. Which I believe is white sec, yellow primary and 68gm, but not 100% on the weights. I just ordered a D&D shift assist and Gills side vents. Just looking to tweak a little without having to shell out to much coin.
M8 orange in the secondary with the D+D shift assist, 65s with the stock primary spring worked good for me in CO last year!
m7
that will work good :beer; I had 05, ran stock spring real tight in secondary.
I also ran 65s in primary, you will over rev a little at times.
Purple cat spring primary, 68s, orange secondary, shift assist. rkt head, stock pipe and can.
