I have a 2006 900 151 with an SLP intake and MBRP can. it was running fine all year until a couple weeks ago now when it is cold it will hesitate and miss right around 5000RPM. Even after a short stop on the trail and everything cools down a bit. Once it is fully warmed up it will run fine with a slight hesitation when the throttle is run to about 1/2-3/4. When pinned it works fine.
Clutching is ok, tps and wiring is fine and I did test the EGT sensor it works when I heat it but hard to relate the resistance to a specific temperature. Stator has all been checked and is within specs. No CEL lights. What could it possibly be? I have done all the other normal stuff like new plugs.
Things I haven't checked
Fuel pressure, Intake air temp sensor, Barometric prssure sensor DET sensor however I would think these sensor would give me a CEL light.
Any ideas??? You guys on here seem to be very knowledgable regarding the 900 issues and this is the first year for me on this sled.
If the sensors weren't $150 each I would buy some new ones to try.
The elevation I ride is 1500 feet as I am not in the mountains.
