05 800 Can't pull start?
C
chopperguy
New member
My wifes sled is an 05 Rev 800 and the pull rope won't engage (to turn the motor over) when I try to pull start it. I have an 05 RT 1000 and I have a shop manual for the RT. It has a fairly straight forward procedure for lubricating the rewind starter and goes as far to say that if you don't maintenance it, you will begin to have the problems I am now having.
Easy enough, however there is a huge difference between accessing the rewind starter on the RT as compared to the 800. The 800 sits behind a part of the tunnel and you can't get to it. From looking at it, I guess you would either need to drill out all of the rivets and take the entire tunnel apart (looks like a huge job) or remove the motor and raise it high enough to get to the rewind starter.
Has anyone done this? Am I way off base and missing something simple? If the book says it is something that needs periodic maintenance I can't imagine them engineering it to be so hard to get to.
Any help would be greatly appreciated.
Easy deal. Use a hole saw and drill some access holes for the four bolts that hold the cover in place. Otherwise you are correct - you will need to pull the motor out. Using the access holes will make this an easy job.
remove muffler, access the screws through the holes that are already in the side frame, you dont drill anything!!!!!!!!!!!!!!!
