Just picked up a 2004 switchback 800 VES
New plugs, valves cleaned. Was told it had the carbs rebuilt end of last season.
Anyways it will sometimes have trouble starting. But will start and idle eventually. 3 or 4 pulls. But rpms seem low. Then when you tap the trottle it will bog and die sometimes. If you feather throttle sometimes it will accelerate then pick up rpms.
Carbs adjusted improperly? Dumping 2 much fuel?
Both plugs wet.
Took valves off and under bellows was a lot of I believe fuel.
Also when idling its blowing out fuel or oil from exhaust.
150psi in both cylinders
Both plugs wet.
