My 2002 summit 700 will not rev above 7000 RPMs, but it worked fine earlier in the day. Any ideas
Carb icing? (turn on carb heaters if cold enough). Carb or fuel filter blockage, possibly fuel tank vent kinked or blocked? Or maybe a clutching issue... broken spring or something...
They do on my 02 Summit 800 HM-X... not sure about your sled... on mine there is a black hose that runs to the left (pto) side carb from the engine, it has a red know on an inline valve to open and close the water flow to the heated carbs, if you have them on your sled. Never had to turn it on myself though. I hear you only need it when it is really cold, and recommended to turn off above like 20 degrees? F, depending on snow / humidity conditions... not sure on all that though, no manual with my sled.how do you turn on carb heaters? do they exist?![]()
