I took a 2" rise off my 2002 and installed a 5" or 6", I am 6' 1" Great in the steep and deep. The 02's have a longer steering post than the newer escapes and edges. The tipped forward riser sounds like a good way to go. I would try and get one higher though. I installed a Power Mad throttle cable extension and bought a new SLP extended brade line. Was easy no issues with cable or throttle.
Now on mine I have the factory four bolt plate on the end of steering post. I put a piece of pipe that extends either side of clamp and my riser bolts on each side. I am very happy with how high they are, but with the riser bolted to either side of steering post when I put on handlebars the risers just catch the upward curl of the bars and can't get them tight enough that they won't move. The VE's has the shorter steering post but no clamp on end the post has a tee top (T). I read on here somewhere where somebody cut there 02 post off and welded a tee on. That is what I am going to do, and make it same length as VE's. Then I am going to get Rox FX Adjustable Riser. 6 to 9".
