I'm 6'6" and considering upgrading my 14 to a 2020 expert.
I'm slightly concerned with a couple things.
1) the short riser.
2) Narrow grips, no I want wider grips my hands are huge.
3) The limit strap adjuster looks like I would be kicking it and bending it with my foot.
1 and 2 are easy to fix.
I have the adjustable riser on my 14, and i run it about in the middle. I have tried it all the way out and it feels stupid., but all the way low feels horrible for me too.
What is the rise diff between the X and the Expert? maybe I can get the dealer to throw in a riser for me.
Also, at least with my 14 SP, the shocks would bottom out under the sleds own weight on its side which meant every time i side hilled it was riding bottomed out, same with my friends 14 X. I put fox evols on mine and it made a huge diff. Are the shocks on the expert any better ?
If I was your dealer I would easily put a 6.5 inch riser on it and just swap out the 4.7 as it will be easy to see, or you could do this, lots of people purchase one, you could try the grips but I agree you might want the regular or a thicker grip on regular bars, again easy to swap out yourself or have dealer do as someone with an x will want that bar or go cheetah factory racing with bigger grips. And no you won't bend or break the limiter strap adjust off, it is designed that way, the shocks are pretty amazing however you may need to get stiffer, mostly likely will have to , springs, I would also agree that a 175 would be perfect for you and yo could add the spindles, seat if you wanted to and upgrade you suspension, but the expert will be cheaper for what you get and if you need to update your suspension as you feel you can do that. cheers dave
