how much boost for the 1400 miles turbo'd ?
thanks
Have you done compression checks to see if you’ve lost any since it was new?
Why?? Unless you have a known issue, just run it.
Rk tek makes a much better piston than polaris. There is a reason factories have copied his designs several times and continue to do so with newer motors.
More pics
xpturbo600 - I believe strongly that your information is not correct and you may want to check into it a bit more.
Here is my take on the subject.
#1 - My experience has told me no aftermarket Company makes a better piston than the OEMs
#2 - From my experience - contrary to what you think ..... RK-Tek has not design or ever manufactured a production piston. And chances are never will.
#3 - From my experience..... No OEM has ever copied any of My ideas or RK-TEK’s ideas...... about pistons.
I believe there is a lot of "fear mongering" around these pistons.... thinking the factory pistons are junk.
I'll take a little wager here on a public forum.
Here it is: The guy that started this thread that’s worried about his turbo Axys W/ 2000 miles on the OEM pistons... Put your engine back together with the current Pistons and run it...I'll warrantee your motor until 5000 miles.
I dare anyone to take a brand new Axys 0 miles put a set of wisecos or woosners...... ** Pro-X ... That Wiseco bought the tooling then had copied in Tiwain - the worst piston i have seen yet. ** turbo it.... and then ride it for 5000 miles. buy a helicoper you will need it.
** I worked to Create a less expensive top-end kit 2 years ago i ordered somewhere between 200 sets of Pro-X Pistons from Wiseco company..........
The ones that they claimed were THE Same as the ART Japan made ones and they bought the tooling...... and then copied exactly...... COMPLETELY WRONG AND A FLAT LIE. - THOSE WERE JUNK, NOT EVEN GOOD PAPER WEIGHTS.
The suppleir came up to my shop and ask me how things were going........... So i told them. ** How many do you think they warrantied ? You guessed it.... ZERO
I Paid out of my pocket to replace almost all of them with new OEM's..... no problems after that.
The most painful part of my **PRO-X experiment ** was most cylinder were destroyed by a sub-par ring...... and most of the others lost a ring locator before they could ruin the cylinder.
I dare anyone to take the bet.
xpturboman600 - And contrary to what you think and believe…
To the best of my knowledge - RK-TEK - did not design and build the Wiseco piston, or the German Built Wosner piston.
xpturbo66 - I am pretty sure you should check with RK-Tek before you post info like you did.......Because i do not ever remember them claiming they had designed manufactured
the greatest piston in the world as you mentioned.
Dan
