- Engagement is right at 3450-3500rpm.
- The plastics on the hood that feed the big vents looks like it's gonna have issues with breaking or catching on trees/snow and breaking. Belly pan has a little area in front to help float, but looks like it can break too.
- Nice fuel panel, they are using the exact same relays that are failing in the axys though, but look much more protected from moisture. There is a cover that goes over it, just took it off for a pic.
- The driveshaft on this demo was steel still. Hard to tell if jackshaft is hollowed.
- No adjustment on deflection on the secondary. There is a plastic support on the plastics so the side panels don't push into the clutches.
- Intakes frogzskins on top and bottom are different, and look like an even better design.
- Side panels are 1lb lighter than the Skinz helium side panels. Side panels look great in person. Very sleek and look to flow perfect with the spindles. It's gonna go through pow and steep sidehills well.
- More room in front of primary to get belt off. Belt is 111. Looks like a similar material to the 083, but slightly different. Definitely looks like a better non glazing material compared to the 084. I think this will be a good belt.
- Headlights are halogen on the demo
- A straight T30 Torx screw driver in your tool kit will work much better than the right angle tool they give you to get the hood off
