Who Makes The Side Panel Vents That?
Spaarky
3,429
1,345
Chester, SD
Who makes the side panel vents that only cover the lower portion of the side panel? I have been going through all the web pages in my favorites and cant seem to find it...
The ones that allow you to keep the stock decals......
thanks.. Justin
Kale
33
www.flaneinc.com p. 50 of Mod-Stock vol. 35 issue 8.
I don't personally have them on my sled, but will probably try them on my next sled.
Give us an update next season if you buy them, and how you like them.
Thanks,
Kale
N
Nelson
1,496
73
48
39
Libby, Montana/Elko, Nevada
Fire'N'Ice makes them. I believe they are available in black,white and red.
firenice.us
Kale
33
Nelson,
Those are sweet. Do they make the brushed aluminum in anodized black?
Kale
Spaarky
3,429
1,345
Chester, SD
Those look pretty nice... wonder if he would buildem without the section cut out for the reflector?
Kale
33
The Fast Lane vents don't have the reflector cut out and they're black, but they look like they have less vent opening.
Kale
Spaarky
3,429
1,345
Chester, SD
Opinions?... think they move enough air to even be worth it? seems like they would be in the snow a lot?
Thanks for all the help and links!!!!!!!!!
W
I put some on my 09 d8 and they work pretty good. My first belt lasted 850 miles and the thread just started to come out so I changed it. The only problem that I had was in real deep fine powder it would let a little snow in on the clutch. Hope that helps
Spaarky
3,429
1,345
Chester, SD
did you combine them with any other vents?
what brand did you get?
yes it is a help... any info is help as long as it is not bashing or being an azzz
sledhead ut
Hot air rises and needs to escape. I don't see a lot of value in small vent being that low on the sled. Beings they're on the side, the air will most likely be passing on by. Air needs to be forced or pressured in and then allowed to escape. My .02
Spaarky
3,429
1,345
Chester, SD
ya... I understand your theory. Mine is if a little bit is good a whole lot is better. I have more vents on my sled than I can count. This is the wifes sled, and she wants to keep the decals... was hoping this was a decent substitute for a side panel vent. Maybe not...
LPIdaho
271
83
IF,ID
I'd say when it comes to venting, anything is better than nothing.
you will not have any snow come through unless it is real icy granular snow
J
jafraune
705
72
wyoming
Like stated above....the air needs to escape, I think the side panel vents really help out when air is passing through the sled....aka while its in motion...
J
jafraune
705
72
wyoming
I dont think so.....they fit just perfect for my RMK side panels. You could probably make some pretty easily with some abs material, pre filter and a hot glue gun
J
jafraune
705
72
wyoming
I don't think the fusion side panels are any different than the RMK's have been since 2005. If I'm right then there won't be any problems.
I know the panels are different....i just dont know if they will fit or not....
Pic of fusion side panel
