Weight/ Helix/ Gear setup
sleddude
118
Yakima WA
Eric, do you have a part number for the 64-42 Helix? I'm at Lake Tahoe and won't be home until next week and on the phone with my dealer yesterday trying to get one of these Helix's ordered for my buddies 05 900 with 151 to try out when I get back but they say they can't find it. This is for the TSS-98 secondary right? Its not a custom cut Helix is it? Did you mean 62/44.46 maybe?
WPS part #30-420494
http://www.carlscycle.com/eshopprod_cat_3799-24094_product_476433.TEAM174_TWIN_TRAX174_HEL.htm
shortstop20
209
South Dakota
A guy I know just bought an '05 900 RMK 151". Has SLP pipe, airbox(not sure who's airbox), vents(again not sure who's). All updates are done. Rider is about 210 pounds or so, not a big hill climber or anything like that, just trail riding and some general off trail riding as well.
He would be riding at 1500 ft.(here in SD, flatlands), the Black Hills(4-7K feet) and possibly the Bighorn mountains as well(7-10K feet). I'm looking for clutching setups for these elevations. He's not much of a clutch guy so if possible something where he'd only have to change the weights would be a plus. As long as it doesn't blow belts and the performance is good, that's good enough, not looking to get every inch out of her.
Seems like the black/red and 66/44.46 helix are pretty much unanimous among 900 riders? What about the primary?
Is the 115 belt mandatory on these sleds or can you get by with the 080? I don't think he's gonna be happy when I tell him belts are $150 each. :rolleyes::face-icon-small-sho
Thanks
H
Jan 9, 2008
2,818
399
83
Woodland, WA
Thanks
Wait til he hears Polaris raised the price to almost $200 for them:mad:
shortstop20
209
South Dakota
a guy i know just bought an '05 900 rmk 151". Has slp pipe, airbox(not sure who's airbox), vents(again not sure who's). All updates are done. Rider is about 210 pounds or so, not a big hill climber or anything like that, just trail riding and some general off trail riding as well.
He would be riding at 1500 ft.(here in sd, flatlands), the black hills(4-7k feet) and possibly the bighorn mountains as well(7-10k feet). I'm looking for clutching setups for these elevations. He's not much of a clutch guy so if possible something where he'd only have to change the weights would be a plus. As long as it doesn't blow belts and the performance is good, that's good enough, not looking to get every inch out of her.
Is the 115 belt mandatory on these sleds or can you get by with the 080? I don't think he's gonna be happy when i tell him belts are $150 each. :rolleyes::face-icon-small-sho
thanks
ttt
H
High Velocity
1,050
497
83
61
Hinton, Alberta
My '06 900-159 has the SLP single and reflash, SLP airbox and V-Force 3 reeds, as well as about 50 lbs. of weight removed. I ride between 4,000 - 7,000 feet.
My clutching is : Primary - 74g MTX weights with 2g rivet in the middle and 3g rivet in the tip - total of 79 grams, SLP black/yellow spring
(120-310 if I remember correctly).
Secondary - 70-42-.46 with Red/Pink spring.
Gearing was 19/42. With this setup, sled pulled very hard, but was still hitting the rev limiter (8050 rpm) quite often. I've regeared to 20/42 and hope to get out for a ride soon to try it out.
Dogmeat
5,343
1,486
Castle Rock, CO
I am still trying to learn about this to see what I should be doing with the mods I have (a couple power adders I guess) and the Arctic Cat clutch ...
Right now I have my secondary set up just like everyone else, but the primary is set up just like you would for a stock 2003 King Cat 900 @ 8,000 feet ...
It works and is much peppier than stock, but I still feel like I have some tuning to do in the primary.
I have noticed I can't hold 7800 RPM a lot of times it seems to me it should be, but then again I really haven't had a lot of seat time latley ..
I think I finaly got all the kinks worked out of everything today :)
I'll let you all know how it goes.
sleddude
118
Yakima WA
Thanks sleddude! Did you try anything different with your clutching and gearing yet?
I installed the 66-44 helix and red/pink spring. I changed my gearing to 19/42 last spring which made a big difference to. My belt stays way cooler as a result. Got into some deep powder yesterday and couldn't be happier with this set up. :):D:beer;
AaronBND
1,696
449
83
Cascade Mnts, OR.
What is your elevation, type of snow and your primary spring color? Just curious.
Aaron
N
Nelson
1,496
73
48
39
Libby, Montana/Elko, Nevada
Glad its working out for you. After talking to Mountainhorse on this thread I got my buddies talked into going from the red/black spring to the red/pink spring on my old 900's, been working good so far.
Dogmeat
5,343
1,486
Castle Rock, CO
What is different about the Red/Pink spring than the stock spring, and how does it effect shift quality, and what alititudes is it good for?
I still have the stock spring in my secondary.
H
High Velocity
1,050
497
83
61
Hinton, Alberta
Dogmeat, the stock spring is a red/black (I think) which is a 140/240. The red/pink is a 140/260. Same starting rate, but 20 lbs higher finish rate. Red/pink should give you a little better backshift and a little more belt pinch. Hopefully others with more clutching experience will chime in and correct me if I'm mistaken.
guidoxpress
5,105
1,506
Wasilla, AK from MT
TTT,
good info..but looking at the helix's online and there is 2 different ones for the same angles..one for standard and one for LIGHTWEIGHT..
which would you get..is there a diff..
i have 05 900, tss-98..
ride at 6000-8000
will go for the red/pink spring..
have lightning 70 weights/Team Green spring in Primary..
also, i bought 18/40 gears but not sure if i should use them, or do 19/41..will stock chain work (dont know pitch of it)
inputs??
H
High Velocity
1,050
497
83
61
Hinton, Alberta
guido, the "lightweight" helix is for the TSS-04 secondary and the "standard" helix is for the TSS-98.
Can't help you out with the gear/chain combos as my manual is for an '06.
GKR
177
Edmonton
Guido,
I believe many on here are running the 18/40 with stock chain successfully. I went with 19/42 and bought the longer chain. go with the lowest gearing you can, it really wakes these things up and is much easier on the belts.
Gary
guidoxpress
5,105
1,506
Wasilla, AK from MT
GKR,
Thank you for the help..i will install the 18/40 then..balance the primary and work on the secondary after i do that..
ANYONE HAVE INPUTS ON HEELCLICKER WIEGHTS for an 05 900???
i boutgh them cause they were a good deal, but i dont know if i want to machine the primary to use them??
N
Nelson
1,496
73
48
39
Guido, one thing you need to keep in mind is that you should always go with the largest gears while trying to meet your gear ratio, more chain contacting the gear which increases the life of your gears and chaincase. 18/40=2.22:1 gear ratio, 19/42=2.21:1 gear ratio, and 20/44=2.20:1 gear ratio, personally I like the stock set up(19/42) over the 18/40 that you chose.
Just my .02:beer;
N
Nelson
1,496
73
48
39
TTT,
ride at 6000-8000
inputs??
Your 05 900 has the larger 11.35 chaincase so:
19/41 (2.16:1 gear ratio) will take a 90 or 92 pitch chain
18/40 (2.22:1 gaer ratio) will take a 90 pitch chain
19/42 (2.21:1 gear ratio) will take a 92 pitch chain
guidoxpress
5,105
1,506
Wasilla, AK from MT
nelson.
thanks for the inputs buddy.
i do like the 18/40..but i think i have a 19/41 also laying around..so i think i willl give it a shot and see..as long as i can use the same chain..(cant afford to buy a longer one)
will it throw off the speedo..didnt know last tim ei went cause my buddies speedo never works..haha..
