This is a small thing, but an easy fix. My side panel clips became extremely difficult to turn to remove the panels in cold weather. Sprayed some silicone spray (aerosol type) in between the plastic clip and the rubber washer by prying out on the clip slightly and spraying some in there. Also sprayed some in from the bottom side where the “L” shape of the clip is. This has made panel removal, especially when cold, much easier. The clips turn with ease now. I know it’s a small thing, and some may not have an issue with this, but I figured I’d share in case it might make someone’s life a little easier.
