I mean no offence to Dogmeat, but he either got the worst 900 ever,
or he doesn't know what he is doing either to have the number of problems he as had, and showcased to us here for help. So if you look into his posts you'll get a unnecessarily bleak outlook.
Actually, it was the exact opposite. I got my 900 in Feb. 2007 for $7,000 knowing full well that I was going to have a lot of work to do to it. I was completley aware of that as I'd been following the forum and reading up on them the previous season. I knew the day I bought it I was going to have to gear it down, do the motor mounts, and some clutching and venting on it. I was completley %100 willing to do the work on the sled myself and learn as I went.
What completley bit me in the *** about it was that when I moved to Vernal, the guy whose house I was moving into specifically told me there was a garage there I could work on my sled in. As soon as I showed up in town, I come to find out it was a car port, not a garage. Now, the last two winters around here, but especially the winter of 2007/2008 it was 20 below here DURING BROAD DAYLIGHT .... IE, kinda ****ty weather to be outside working on a sled, especially when you're a newbie to it.
Anyways, after I got it, it dawned on me I was not set up to work on it myself at all, which if you're building a 900 is what you have to do unless you're dealing with a very competent shop.
Anyways, I had some spare coin at the time, and I really wanted to make the 900 run well, so I thought "Well, if I have the dealership just pull the motor for me and do the motor mounts and send the bottom end off to Indy Specialty, they can just slap it all back together for me and then I'll I'll have to mess with is the clutching".
This was my first mistake. The dealership that I took it to, was not anywhere near as competent as I thought they were. As soon as I got the sled back from them, I had
all kinds of electrical problems with it that plagued the sled for the next season as well. They pinched off the wiring harness when they put the motor back in, and it wasn't until I finally just got so pissed off being unable to do the work myself I took the sled to another dealer. They told me my TPS sensor was fried as well as the TPS harness ... so I was like "Ok, fix it", so they did.
The sled then ran right for one ride before I started having electrical problems again, that lasted until last season.
Finally after a ride last season where the sled had to be towed back, and basically with me not having a clue how to fix the electrical problems, I opted to just part the sled out and sell it to somone who had the time and patience to work on the sled, but then it dawned on me with all I had into it I wasn't even going to be able to SELL it let alone get anything out of it...
So, I hauled the thing all the way up to Boise to Carl's Cycle and told them to pull the motor, go through the wiring harness, and just flat out fix the sled. They also removed the hoakey RMX package I had RMX do to it and replaced all that with the SLP kit.
Anyways, the moral of the story is, I knew full well what I was getting into, and the ONLY problem I had with my 900 the season I bought it and rode it stock was that I blew one 1080 belt the first real powder day at Rabbit Ears I ever had on it.
My main mistake was taking it to a dealer that just didn't give a **** whether or not they put the sled back together right ..... so this is why I say if you're gonna buy one of these things, you better have the time and patience to do the work YOURSELF so you know it's done right .... IMO, I would not recommend buying a 900 for your first sled. If you've been sledding awhile and know how to work on one and what it is going to take to get one set up properly, then by all means get one.
Finally, I've got my 900 running pretty well. It's basically a "big boondocker", which I am perfectly happy with the power/manueverabillity/weight ratio of the thing. It is not the lightest sled, but it's not the heaviest, and it's got a TON of torque for climbing hills and boon docking ... Once you get the clutching and gearing right on them and get used to the heavy nose, you can really ride the piss out of them. When the 900's are set up right, they're a tough sled to beat IMO ...
Only thing left for me to do on my 900 is gonna be replace the A-arm I bent last ride and put the 8" RSI handlebar setup on it, and I'm gonna be ready to rock and roll with it this winter....OH and finally figure out an air intake for it that actualy works.
And mayb eput some new plastic on it cuz I banged the hell out of that last season too.
Anyways, my $0.02.
