Service Bulletin BS201312 - Slide Rail End Caps 2013 Ms
Dam Dave
4,302
2,252
Montrose
i thought the general concensus was to leave the outer wheels in place??
Not unless you want bent rails.........just look how they are mounted and imagine the twisting forces applied to the rails.........even going down a bumpy trail your rails are probably bending back and forth as those wheel hit bumps
some people will never have an issue with it but when you do it will ruin your day
kylant
1,669
394
83
CA
thanks,
tomorrow my anti-stab kit goes on and the idler wheel delete kit. i will remove the inner and outer wheels.
i will also try to get another rod for in between the rails where the inner wheels were
i noticed on my delete kit, the rod or axle is not threaded. is the rod that holds the front shock threaded, or is it just one long bolt? confused
northof40
313
80
Saskatchewan
I havent heard a thing either other then on here and from michelle. I have been running an anti stab since new so i wasnt to concerned.
sledrider
44
Wherever the snow is
It was a "service bulletin" not a recall.
Cat does not contact owners for service bulletins, they only instruct dealers to install the next time sled is in for service......
That being said my dealer did contact me. :)
