KMOD,
I'm very interested in the Evol Gen ll set up for my M8. How much travel does the M rear gain with the Gen ll installed. It looks like its jacked up in the rear 3-4"s.??? Do you get more ski pressure because of this lift? I need less ski pressure as it is now. Also, do you revalve front shocks?
I haven't measured exactly but on the bench the ride height should increase about 1.5'' which is all travel, the Nytro is a little more than that but I have a way to adjust the ride height if needed.
On all the sleds we have installed we usually end up lengthening the straps out to get the ski presure right, not to heavy at all.
The beauty of this skid is it rides very good and still keeps the front end down, and with the Evol shock there are 2 air chambers to adjust, dampening adjustment, and still have the coupling bocks if needed.
It is very adjustable and very easy to adjust on the hill.
The Nytro with MCE turbo at 16lb in heavy corn snow road very nice all day but when he went through a wash and climbed a steep and long hill on the other side it stayed very flat and just railed up the hill.
Have a good ride and still stay flat with the skis just above the snow going up hill with boost.
Haven't tested with 153 track yet and don't know if it will fit without some custom rails??? and also can't make it fit on 08 rails all the holes are in the wrong place, but the 09 rails I have custom plugs made and the 07 rails we just drill new holes.
On the M Cats we have tested with the stock front arm and the Gen ll in the rear, it works as good as long as the front rail shock is lengthend and longer straps, may be an option for less money.
All skids fit in the stock mounting brackets and holes.
Thanks Kevin
