Purpose built snowbike
fgauvin7
92
116
33
On another note, huge thanks to eric82930 for the advice on the rear engine mount!
I did not have any space with the new tank for a cross brace so I ended up just building the strongest mount possible in the space that I had! I was lucky to have some space available in the tunnel just bellow the mount. So I was able to fit two 1in square tube .125in wall into the tunnel flush with the sheet metal and build some strong mount from that.
Tested it yesterday, the difference is outstanding! Most of the problem is gone I think, I have to test it more but it is definitely a big improvement. for the rest of the vibration, well it is a 8-9000rpm single cyl.... It won't change that much
I hope It will be easier to have some reliability now! So I can do more riding!
135749633_418937492491979_908486170792726079_n.jpg135788666_238876840939646_3119244618868605288_n.jpg
B
Feb 4, 2011
224
512
93
Thanks @fgauvin7 for your detailed thoughts on the various components. Your thinking about the a-arm front suspension makes sense. I'm still on the fence whether it would be a real advantage or not but I like the concept and I'm gonna continue to entertain it.
For something easy, I'm with @eric82930 on lowering the head tube and using a short ski spindle. I have another bike that I've been screwing with over the years which is now obsolete since I no longer use motorcycle engines. It's the perfect candidate for some front end experiments. This bike's engine will get replaced with a sled engine and clutches. @fgauvin7 I cannot encourage you enough to give a sled engine a try. Don't be afraid of the width. I originally was but found it is non-consequential. Center the power plant so that the flywheel/stator cover and the primary clutch stick out equally on both sides of the machine. The cylinders will be offset to one side under the hood but this makes no difference. Anticipate the total width at around 24 inches (60cm). It's totally acceptable in my opinion.
Again, good work and I hope you will continue to post info about what you're up to. I love this stuff!
B
Feb 4, 2011
224
512
93
One more thing for what it's worth. I've screwed around with rake angles from 25 degrees to 30 degrees and to be honest, I can't really tell much difference. It would be neat to build up a machine where you could easily adjust rake and trail to really get a feel of the differences.
fgauvin7
92
116
33
Thanks @Brett Kobernik, yes I think I will go forward with the sled engine and explore that trail for the moment! As you said I dont mind having a small 3-4in bump on each side to make room for the engine. I just want to keep the overall machine compact and slim. I'm on the same track as you I think on the varous point for the next build, lowered fork with long stem tube, short ski spindle, low CG 2 stroke twin centered in the chassis. I would retain most of the geometry of my actual bike since it is working good, I will just improve some point as talked before. I think a steeper fork rake could be a winner but an ajustable setup sure would be nice and not too hard to acheive.
My frame jig is done too! I just need to fab some mount for the component, this jig will allow me to assemble and test new layout without having any frame work. When I will have something I like I could then run some tube and build some structure to support everyting. Also it will be pretty easy to trasnfer the machine layout to the 3D modelling software since I have some reference to measure form.
E
Dec 19, 2007
1,041
657
I agree the rake itself isn't that big a deal but what I notice is the steeper rake feels better in hard snow and slack rake is better in soft snow. It is mostly due to the fact the the side wings on the ski dig in more with slack angles which makes the ski more aggressive bite in pow but miserable on hardpack. We could get the same affect by swapping between the backcountry and traverse ski.
The low center of gravity is important too. my raptor is a tall engine and the head is massive. It really makes me struggle to lift up after a tip over. Having a wide cvt cover on a sled based engine might actually help make it easier to flip back up. When sleds tip over the bars might be in the snow but then the track is in the air as a counter weight pivoting on the cvt covers.
But I keep coming back to the over all weight issue can't be totally ignored which must be one of the problems of the snowhawk. and there is a fun factor that a 217lb bike with a skinny short track will always win over a 400lb bike with a long wide track. My goal is to have one of each some day.
Hawkster
8,215
6,424
AK
That's good
An adjustable rake makes way to much sense , an eccentric bolt or cam bolt kit with a death lock lever making it adjustable in the field . The ski seriously scrubs ponies when needed .
I like it :)
E
Dec 19, 2007
1,041
657
So field adjustable might be tough but here is my plan. I will turn down the outer tubes on my forks so they are the same diameter as the top all the way down. Then I will get an extra top clamp to put on the bottom down by the lower seals. I'm thinking of not using a stem at all but instead possibly ball joints with adjustable threads. Sourced from a utv or slightly hd than a sled ball joint.
Sheetmetalfab
7,919
6,681
Big ball joints are very stiff to turn unless you get the bronze oilite version.
Stay away from the ptfe race.
fgauvin7
92
116
33
Little update on the project!
Snow is mostly gone around here, it has been a very short winter over all with not much snow to to play with. But I enjoyed the snowbike experience a lot even with this amount of snow. For me it is an advantage over my M8000, I need a lot less snow and spot are very easy to find.
I didn't put a lot of hours on it, but my main goal for this winter was to dial it and solve the issue there might be. On this part I can say that most issue are gone now, vibration is very minimal with the new engine mount and the addition of a rubber mounted handlebar. Last ride I did I had some trouble with an iced up carburetor, but since then I added a carb heater and a neoprene blanket. This should solve the problem for next year. Body panels would help a lot through, we will see this summer if I can add something to cover it. It won't be simple since the chassis is not designed to have a body... I'm on the V2 at the moment, so there is a possibility that I will put the effort on the new one to make something look nice and leave the actual build as is if the carb is covered enough.
On the chassis side, I did not touch anything this winter, rear suspension, front suspension, steering.... Everything just worked! I need to work with a friend to do a custom suspension valving that would suit more the build.
Next build should have a bit more seat height, 33in is a bit low, feels good in the shop but out in the snow it is a different story. Around 2in more could improve foot drag and still provide a user friendly seat height.
This winter I was also lucky enough to participate in a tv show and describe what I have done with this project! I was a pretty fun experience and I have had a lot of feedback in the last few weeks! Unfortunately it is in French but some of you may like to see it...
Thanks for everyone input along the winter! There is still a lot to be done and many idea to try, but it is nice to be able to ride something and learn to be able to make the next one even better! By the way I'm looking to name this project, I have not found anything yet that I like... So if some of you have some proposition I'm all open! :D
E
Dec 19, 2007
1,041
657
We call our naked home builds "Skelator"
There is a brand new cheap counter balanced 17 250sx motor to be had on the local classifieds here that would love to find a home in that frame! But I'm guessing your out of the country?
E
Dec 19, 2007
1,041
657
I was told a prototype was built but cat isn't persuing it because of demand. the Polaris rep also told me they'feel a kit is best because it can be used year round. Nothing new to get excited about this year it seems.
fgauvin7
92
116
33
Dusting off this thread!
I have not worked a lot on this project since last winter. Only update are a carb heater and an anti vibration riser. Ideally I would need to fab some sort of side panel for this winter to minimize carb icing. Everything else work just fine for now... Riding was also on hold this winter due to the weather, January here was between -25c to -40c so there is no way I would ride this thing without a heated handlebar like the current setup. Temps looks to be going up for February so I hope I will be able to take it for a few ride.
In the mean time I had been working on the v2. Well I don't think we can call it v2 since there is pretty much anything in common with what I have built last year... Only thing that I have kept is experience and knowledge! The design of the v2 was with completely different objective than the v1, but the first version helped me a lot in finding what I want and what I need.
On this one it is not about minimal weight and be as ''out of the box as possible'' that matter, while weight is still a consideration and creative solutions are still the name of the game there is more this time. I want it to be a flexible in the power plant choice, have as much room as possible, good ergo and professional look and be simple in its design.
So I designed it around the Arctic cat Blast engine and around a yz450f engine, there is enough room to fit both but the Blast would be a very tight fit and need some small tweak to the final bodywork. For now I have found a 450f that I may be able to get... we will see if I can close the deal on it. For the chassis I switched to a twin rail setup in the narrow Yeti spacing along with a brand new Yeti 129 track, no more splice on this one! Dual fox float rear suspension in a classic geometry more like an ARO or a Yeti. In the front I opted for forks instead of the front facing A-arm setup. There is notting wrong with the A-arm setup, in fact it works very well and I have not touched it once, but this setup take a lot of space and require a lot of fab work.
Last year we discussed on this thread of the ball joint mount for the fork setup, I was not sure about the simplicity and I even built two frame section for the V2 to be able to make a good decision. Finally the V2 will have the ball joint design since it add so much space down low and distribute the load quite well I think.
Here is some picture of the last few months, A lot of work has been done and the hard part is that everything has to be built and designed at the same time to ensure a proper fit of the bodywork and ensure that I success in my objective to have a nice professional look on this one!
Here is the last evolution of the tunnel design
New drive shaft setup
new rear suspension
272099871_2143451799154776_8466652823782099540_n.jpg272092265_275707091297528_1648758509952507467_n.jpg
Mostly the final front chassis section, there will be a bit more bracing but you get the idea...
And finally there is the icing on the cake! A real piece of bodywork. Molds will be pulled from this plug and fibreglass prototype version will be used. Some day a carbon version would be the ultimate goal.
B
Feb 4, 2011
224
512
93
Tight!! I've also thought about that Arctic Cat engine. If it were me, there's no way I'd screw around with the YZ450. Go for the Blast and CV clutches. You won't be sorry. What did you end up using for spacers on the lower triple clamp to get them to tighten up on the forks?
fgauvin7
92
116
33
For now it is a 3D printed sleeve but it will get changed for a proper machined bushing for testing and I might build a custom triple clamp with the proper diameter in the future.
E
Dec 19, 2007
1,041
657
Lookin good! After you figure out which engine/pipe you should try to use two smaller tubes to connect to the bottom ball joint in an A shape. It will be stronger if someone pulls the ski sideways to get un stuck. What ball joint did you end up using in the tclamps?
I just got done updating my lower clamp to use a Polaris ranger ball joint. I also took the plunge and cut down my outer fork tubes so I can use a top clamp on the bottom with no spacer.DSC_1161.JPG
