Polaris mod project questions?
Hi, i am a 15 year old that just bought a 2001 rmk 800 that needs some engine work done. I am going to try to pursue the carrer of snowmobile,dirt bike, and quad mechanics. So i will be doing the work by myself. Right now i know it needs new pistons and cylinders.......what is the biggest bore i can do with the stock crank? I could really use some help, so anything is good.
Thank you
And yes, i know i need to change my snowest name haha
M
Jun 15, 2009
2,866
97
48
Marshfield, WI.
So you are asking for big bore options for an 01 800? I would go with a new stock ves top end and have your crank checked out,trued,bearings replaced if it needs them. Then twin pipe it tune it and have funn .
M
mod03rmk800
57
missoula
Are you sure the cylinders are toast? They may only need cleaned with acid or sent off to get re-nic'd or worse case re-sleeved. Stock Polaris pistons are easier to get and a solid piston. Over-bore alone won't gain much if any in performance.IMO
The crank more than likely is close to, if not shot with all the upper damage. That one is going to hurt($)! Some porting and a pipe(s) will make for some fun. Should do some new reeds,water pump belt,drive belt,check all mounts and clean and inspect EVERYTHING else.
M
mod03rmk800
57
missoula
rmk727
568
154
SO.DAK
You'll get alot more and better info with a proper name change say doowhacker , or catsuck you know something mild yet forceful.
